Just Ordered Some JD Traction Bars!
I ordered a set of extra JD-style brackets from Underdog Performance. I thought I got his last set, but they're still on his site:
http://www.underdog-performance.com/id87.html
You can take your JDs to a metal shop and ask them to replicate another pair, or buy a pair from Underdog. Because JD uses two holes, and UDP only has one hole, they are not compatible. I wish I would have know that ahead of time...
Or your can put a pair of JDs on one side of the truck, and a pair of UDPs on the other side. Bottom line is that you can't mix-and-match two different styles on the same traction bar.
If you can get a set of brackets from Underdog ($15 shipped), I'll trade you my UDP brackets for your JD brackets (or vice versa). You'll have two matched pairs, I'll have two matched pairs. I just gotta buy my JD bars first! Seriously, let me know...
Originally Posted by graniteguy
if memory serves me right, you got actual JD brackets. I put my own doubles over each bracket so I didn't need them. JD did change the style of them so it may not have matched the brackets you had. The ones I have are a two hole.
Thanks Wayne, I just have to get off my butt and order the bars!
FWIW: This is what the brackets that I got from JD looked like. I ordered late June 2005.
My brackets had to have the slots elnarged and have the insides of the perches filed down to fit my 31-spline LII axle.
Here are all kinds of photos of the install:
http://www.pbase.com/nhbubba/jdtractionbarinstall
Lol. Forget about my mounts. Every comment made has been that they will not mate directly with JD mounts, you would have to swap them all. I think the confusion is JD has used two different mounts.
They used to be a mirror image and could be doubled. Look at the pictures. This will help everyone understand. One style of JD bracket allows a double mount because they are a mirror image of each other. If you have two of these and could get hold of two more, you'd have a matching set to double up:
old?
new?
old?
new?
Pinecone
23
03-17-2005 03:31 AM
