SOHC - 2.3L & 2.5L Lima Engines Discussions and Topics specific to the Lima 4 cylinder engines
HELP!! 2.3 dual plug intermittent spark!!
Old 11-07-2005
axel21071's Avatar
91 ranger 2.3L dual plug engine, loses spark intermittently in the exhaust side coil pack. spark comes and goes at will. pulls codes 88(dual plug input control failure) and 18(idm circuit failure). it goes from running great to crappy in an instant(and vice versa). plugs, plug wires, coil packs are all good. ignition module was tested twice, both times it tested ok. any help with this would be appreciated. thanks
Old 11-08-2005
5speedin2.3's Avatar
i had this same problem with my moms truck.. i forget what the thing is called.. its the gray thing that mounts to the intake and has three bolts and plug on each end.. they are $80 new and around $10-20 from a junkyard. also make sure you dont break any of the bolts off..
Old 11-08-2005
axel21071's Avatar
you mean the ignition module.....but i've had it tested twice, and both times it tested ok.....could it still be bad?????
Old 11-08-2005
yeah i had mine tested and it was fine.. was giving me the dual plug code.. part after part later.. got one from a local junkyard and it fixed it. i broke one of the bolts off and the truck wouldnt start.. it has to have ground to one on the left holes for ground..
Old 11-08-2005
axel21071's Avatar
ok, thanks.....by the way....i had it tested again, they ran 5 tests on it and it failed twice but passed 3 times, so i'll get a new one. Thanks Again.....
Old 11-08-2005
yeah the two times is why it is running like that :P
the local junkyard has one.. they want $30 tho..
Old 11-09-2005
axel21071's Avatar
Yes, but 30 is better than 130, which is how much autozone wants for one........
Old 11-10-2005
let me know if you want it, i can get it for you. but try to look around first. i think i payed $15 for the one i have in the truck now.
Old 11-10-2005
axel21071's Avatar
i found one in a local junkyard for 20 bucks, but thanks for the offer though....
Dangerranger01
20
03-08-2016 08:37 PM
rangerdanger9419
08-11-2015 03:02 PM
9440a4ld
09-02-2014 11:12 AM
tluafeD
03-06-2008 10:10 AM
SteveOh
25
11-21-2006 01:27 PM
Quick Reply: HELP!! 2.3 dual plug intermittent spark!!
